Merci de me proposer des solutions. Je pense que je n’ai eu les soucis que sur windows 10, mais je ne pense pas que le problème soit venu rapidement après sinon ça m’aurait alerté je pense.
Voici le rapport :
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.0.0
Monitoring
Mainboard Model H97M-G43(MS-7924) (0x000003D4 - 0xCBF0C090)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6792
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC9
LPCIO Revision ID 0x11
Config Mode I/O address 0x4E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 38 20 08 00 FF FF
20 C9 11 FF 00 04 00 40 11 00 FF 40 00 00 14 00 09
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 20 0A 30 00 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A20
Hardware Monitors
Hardware monitor Nuvoton NCT6792
Voltage 2 3.42 Volts [0xD6] (AVCC)
Voltage 3 3.42 Volts [0xD6] (3VCC)
Voltage 7 0.13 Volts [0x10] (CPU VCORE)
Voltage 8 1.73 Volts [0x6C] (VCCIN)
Voltage 9 1.50 Volts [0x5E] (DRAM)
Voltage 10 11.09 Volts [0x7E] (+12V)
Voltage 11 5.16 Volts [0x81] (+5V)
Temperature 0 25 degC (77 degF) [0x19] (SYSTIN)
Temperature 3 27 degC (80 degF) [0x1B] (TMPIN3)
Fan 1 985 RPM [0x3D9] (CPUFANIN)
Fan 2 867 RPM [0x363] (AUXFANIN0)
Fan 3 889 RPM [0x379] (AUXFANIN1)
Hardware registers
bank 0
00 04 7F 04 1F 00 FF FF FF FF FF FF FF FF FF FF FF
10 04 99 04 99 04 7F 03 7F 40 7F 15 00 7F 5E E9 00
20 6C 81 D6 D6 7E 6B 5C 19 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 3E 47 FF DF 00 3F FF 2D FF FF 10 00 55 00 A3
50 05 FF FF FF FF FF FF FF C1 FF FF FF FF 47 06 FF
60 26 F0 FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 1A 80 1A 80 1A 80 1A 80 1A 80 28 80 FF
80 FF 7F 3F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 03 00
B0 00 00 00 00 00 00 23 00 04 00 00 34 28 C0 04 00
C0 FF FF FF FF FF FF FF FF FF 1E 04 02 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 C0 1F 63 FF FF FF
bank 1
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
80 6C 81 D6 D6 7E 6B 5C D6 CE 7F 15 00 7F 5E E9 00
bank 5
bank 6
bank 7
Hardware monitor ACPI
Temperature 0 28 degC (82 degF) [0xBC2] (TZ00)
Temperature 1 30 degC (85 degF) [0xBD6] (TZ01)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.88 Volts [0x36B] (VIN0)
Power 0 12.38 pc (GPU)
Temperature 0 25 degC (77 degF) [0x19] (TMPIN0)
Fan 0 1150 RPM [0x47E] (FANIN0)
Fan PWM 0 28 pc [0x1C] (FANPWMIN0)
Clock Speed 0 135.00 MHz [0x87] (Graphics)
Clock Speed 1 324.00 MHz [0x87] (Memory)
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
– Core 0
– Thread 0 0
– Core 1
– Thread 0 2
– Core 2
– Thread 0 4
– Core 3
– Thread 0 6
Timers
Perf timer 3.125 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core i5 4460
Codename Haswell
Specification Intel® Core™ i5-4460 CPU @ 3.20GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84.0 Watts
Tjmax 100.0 °C
Core Speed 800.0 MHz
Multiplier x Bus Speed 8.0 x 100.0 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 32x
Max turbo ratio 34x
Max efficiency ratio 8x
O/C bins none
Ratio 1 core 34x
Ratio 2 cores 34x
Ratio 3 cores 33x
Ratio 4 cores 32x
TSC 3200.0 MHz
APERF 1500.0 MHz
MPERF 3199.0 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Temperature 0 23 degC (73 degF) (Core #0)
Temperature 1 23 degC (73 degF) (Core #1)
Temperature 2 24 degC (75 degF) (Core #2)
Temperature 3 23 degC (73 degF) (Core #3)
Temperature 4 27 degC (80 degF) (Package)
Voltage 0 0.72 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Power 0 6.14 W (Package)
Power 1 0.54 W (IA Cores)
Power 2 n.a. (GT)
Power 3 5.59 W (Uncore)
Power 4 0.90 W (DRAM)
Clock Speed 0 799.98 MHz (Core #0)
Clock Speed 1 799.98 MHz (Core #1)
Clock Speed 2 799.98 MHz (Core #2)
Clock Speed 3 799.98 MHz (Core #3)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020205h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306C3 0x06100800 0x7FFAFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B6FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00042120
0x00000006 0x00000077 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x000027AB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x35692029 0x3634342D 0x43202030 0x40205550
0x80000004 0x322E3320 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080838 0xF3012000
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x20212222
MSR 0x00000194 0x00000000 0x00110000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88490800
MSR 0x000001FC 0x00000000 0x0000005D
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00000000 0x00000800
MSR 0x00000610 0x004283C0 0x001D8348
MSR 0x00000611 0x00000000 0x0516DB18
MSR 0x00000639 0x00000000 0x01ED7E03
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x008BE9F6
MSR 0x00000614 0x00000000 0x000002A0
MSR 0x0000019C 0x00000000 0x884D0800
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x000016F7 0x00000800
MSR 0x00000199 0x00000000 0x00000800
Storage
Drive 0
Device Path ?usbstor#disk&ven_&prod_usb_disk_2.0&rev_pmap#070732434b078039&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Name USB DISK 2.0
Capacity 3.7 GB
SMART Support Yes
Volume e:, 3.7 GBytes (1.2 percent available)
Drive 1
Device Path ?scsi#disk&ven_wdc&prod_wd10ezex-08m2na0#4&231b3730&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name WDC WD10EZEX-08M2NA0
Capacity 931.5 GB
SMART Support Yes
Volume c:, 923.2 GBytes (28.7 percent available)
USB Devices
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x1532, product=0x010B
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x1E7D, product=0x2DBF
USB Device Dispositif de stockage de masse USB, class=0x00, subclass=0x00, vendor=0x26BD, product=0x9917
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8009
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8001
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 970
Board Manufacturer ZOTAC International Ltd.
Revision A1
Codename GM204
Technology 28 nm
Memory size 4 GB
Memory type GDDR5
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x19DA)
Model ID 0x13C2 (0x1366)
Performance Level 0
Core clock 135.0 MHz
Memory clock 324.0 MHz
Monitor 0
Model PL2788H (Idek Iiyama)
ID IVM6628
Serial 0
Manufacturing Date Week 0, Year 2016
Size 27.2 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 55-76 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
