Retour au site
Connexion : S'inscrire
5 messages
Filtrer ok
Probleme installation ie7
Un expert informatique vous aide immédiatement par téléphone.
Bonjour, j'ai un souci avec ie7. j'ai réinstallé xp sur mon pc portable et a chaque fois que j'éssaie d'installer ie7 ca me dit que ie7 n'a pas été installé.
Code :
0.328: ================================================================================
0.328: 2008/12/21 16:26:25.515 (local)
0.328: c:\462777c7e3337101fe6cee7ee6327c\update\update.exe (version 6.2.29.0)
0.359: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.359: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
0.359: IECUSTOM: Scanning for proper registry permissions...
0.843: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
0.843: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid
0.859: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid32
0.859: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\TypeLib
1.140: IECUSTOM: Scanning for proper registry permissions...
1.406: IECUSTOM: Scanning for proper registry permissions...
1.734: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.796: IECUSTOM: Backing up registry permissions...
1.812: IECUSTOM: Finished backing up registry permissions...
1.812: IECUSTOM: Setting new registry permissions...
1.812: IECUSTOM: Unable to clear DACLs HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.812: IECUSTOM: Finished setting new registry permissions...
1.812: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
1.812: DoInstallation: CustomizeCall Failed: 0x3f5
1.812: IECUSTOM: Restoring registry permissions...
1.812: IECUSTOM: Finished restoring registry permissions...
1.828: Impossible d'écrire la clé du Registre de configuration.
1.843: L'installation du Internet Explorer 7 ne s'est pas terminée.
1.843: Update.exe extended error code = 0x3f5
0.359: 2008/12/21 16:44:12.984 (local)
0.359: c:\61b10ed25727acdbb500\update\update.exe (version 6.2.29.0)
0.375: Failed To Enable SE_SHUTDOWN_PRIVILEGE
0.375: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
0.375: IECUSTOM: Scanning for proper registry permissions...
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\ProxyStubClsid32
0.797: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}\TypeLib
1.047: IECUSTOM: Scanning for proper registry permissions...
1.297: IECUSTOM: Scanning for proper registry permissions...
1.578: IECUSTOM: Unwriteable key HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.625: IECUSTOM: Backing up registry permissions...
1.641: IECUSTOM: Finished backing up registry permissions...
1.641: IECUSTOM: Setting new registry permissions...
1.641: IECUSTOM: Unable to clear DACLs HKCR\Interface\{34A715A0-6587-11D0-924A-0020AFC7AC4D}
1.641: IECUSTOM: Finished setting new registry permissions...
1.641: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
1.641: DoInstallation: CustomizeCall Failed: 0x3f5
1.641: IECUSTOM: Restoring registry permissions...
1.641: IECUSTOM: Finished restoring registry permissions...
1.656: Impossible d'écrire la clé du Registre de configuration.
1.672: L'installation du Internet Explorer 7 ne s'est pas terminée.
1.672: Update.exe extended error code = 0x3f5
il y a pas mal de clé de registre qui sont unwrittable , est ce que vous sauriez d'ou ca peut venir?
merci d'avancd
bonne journée
Edité le 21/12/2008 à 16:51
Salut (trouvé grâce à Google)
je l'ai fait pour un pote qui avait ce problème de registre sur une install XP toute fraîche
et ça a marché
Si vous déterminez que la cause du problème d'installation est du a de mauvaises autorisations dans le registre vous pouvez essayer de les modifier de la manière suivante :
1. Cliquez sur le bouton démarrer et sélectionnez la commande Executer.
2. Saisissez la ligne de commande suivante dans le champs de texte Ouvrir puis validez en appuyant sur la touche Entrée.
secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /areas REGKEYS
Redémarrez la machine, puis installez IE7.
Je garanti, ça marche!
le probleme c'est qu'il dit qu'il me dit qu'il ne connait pas secedit
ah voila j'ai trouvé un site ou la marche a suivre était expliqué , ici
et ca a marché je suis arrivé a installé ie .
en fait il fallait aller dans regedit trouver un clé de registre et changer l'aurorisations et après tu pouvais installer ie
merci Murmel pour ta réponse.
A+
le site dont tu parles ajoute une info intéressante
Si on installe IE7 après le Service Pack 3 d'XP, on a le problème des droits de la BDR
avant, c'est à dire sous SP2, on ne l'a pas
Dans la base de registre
- Démarrer
- Exécuter
- tapez regedit
- Parcourir le chemin suivant :
HKEY_CLASS_ROOT
Interface
cliquez simplement sur {34A715A0-6587-11D0-924A-0020AFC7AC4D} avec le bouton droit de la souris et choisir Autorisation, cochez Contrôle Total du premier groupe ou de votre session, cliquez OK et fermer la base de registre.
Procéder à l'installation sans redémarrer
J'ai vu que sur le SP3 le contrôle total n'est pas coché comparé au Service Pack 2
5 messages
Filtrer ok
 Sujets Similaires:
