Retour au site
Connexion :
Recherche
14 messages
Filtrer ok
Besoin de conseil - programme de démarrage
bonjour,
J'aimerais savoir quelle programe je peux décocher afin d'avoir un démarrage plus rapide :
Startun Inspector :
C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LDMConf.exe
C:\Program Files\Logitech\SetPoint\KEM.exe
C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE
C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE/IMEName
C:\Program Files\Java\jre1.6.0_01\bin\jusched.exe
C:\Program Files\Fichiers communs\Ulead Systems\AutoDetector\monitor.exe
"C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE /Spoil /RemAdvDef /Migration32"
c:\apps\ABoard\ABoard.exe
C:\PROGRA~1\Wanadoo\Watch.exe
C:\Program Files\Fichiers communs\Real\Update_OB\realsched.exe
C:\WINDOWS\system32\LVCOMSX.EXE
C:\Program Files\Logitech\Video\ISStart.exe
C:\Program Files\Logitech\Video\LogiTray.exe
C:\Program Files\AMD\amd_dc_opt\amd_dc_opt.exe
SOUNDMAN.EXE
C:\Program Files\ATI Technologies\ATI.ACE\CLIStart.exe
C:\Program Files\ZTE Corporation\ZXDSL852\CnxDslTb.exe "ZTE Corporation\ZXDSL852"
%systemroot%\system32\dumprep 0 -k
C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 6.0\avp.exe
C:\PROGRA~1\Wanadoo\GestMaj.exe
C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe
C:\Program Files\Logitech\Video\ManifestEngine.exe"boot
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Messenger\msmsgs.exe/background
C:\Program Files\QuickTime\qttask.exe-atboottime
C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe
C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\OFFICE One6.5\OFFICE One PDF Manager\OoPDFSettingsv6.exe
Tu peux décocher :
  • C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe
  • C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
  • C:\Program Files\iTunes\iTunesHelper.exe
  • C:\Program Files\QuickTime\qttask.exe-atboottime
  • C:\Program Files\Fichiers communs\Real\Update_OB\realsched.exe
  • SOUNDMAN.EXE
  • C:\Program Files\Java\jre1.6.0_01\bin\jusched.exe
Il peut y avoir des choses d'autre, mais je n'en suis pas sûr ...
le barbier fou a écrit:
Tu peux décocher :
  • SOUNDMAN.EXE
OK déjà un grand merci pour ta réponse :jap:
Salut tu peut aussi décocher office one 6.5(je l'avait celui-ci mais je suis passer a word) :hello:
Ok merci
si toute fois il y avait des personnes pour me dire si je peux en décocher d'autre ....
Je décoincerais bien aussi tous les trucs Logitech (c'est pour une webcam?)
Je les avais tous virés chez mon paternel^^
Eventuellement msn :)
Salut ,
Je pense que c'est une bonne idée mais si j'en hote certain je n'ai plus de raccourci clavier et je m'en sers de temps en temps...
sinon celui de la Web cam pourquoi pas mais c'est lequel.
Pour MSN je pense que C une tres bonne idée.
Merci beaucoup Silggins :-)
Garde uniquement ça:
Pour Wanadoo, je ne sait pas trop ce que c'est mais si tu es en WiFi gardes le sinon pas la peine ;]
Pour les Windows\Sys32 décoches les ils vont se remettre d'eux même de toutes les manières.
Sinon petite astuce, au lieu d'utiliser Start Run Inspector, tu peux avoir la même liste en faisant
Démarrer > Executer > msconfig > Onglet Démarrage :]
Tu garde ceux de la liste précédente et tu fais Appliquer.
Pour pousser le truc, tu peux passer sur l'onglet Services, TU COCHE MASQUER TOUS LES SERVICES MICROSOFT (c'est important, et tu le trouvera en bas en dehors de la liste) ensuite tu décoche tout ce qui n'est pas relatif à Kaspersky ou à ta carte graphique, carte son...) ensuite tu fais OK et redemarrer..
En cas de soucis tu peux tout rétablir d'un simple clic Démarrer > Exectuer > msconfig > Onglet Général > Démarrage normal.
Edité le 01/06/2007 à 13:10
merci KlumlpF,
Je vais voir ca ce soir, pour ce qui est d'internet je tourne avec la live box et non plus le modem ZXDSL852 donc je vais le désactiver aussi..
Un grand merci pour ces précieux conseils ;-)
Aprés avoir suivi tes conseils en ce qui concerne les objets de démarrage j'ai ensuite masqué tous les services Microsoft et
il me reste ceci :
Ati HotKey Poller
ATI Smart
Kaspersky
CyberLink Background Capture Service ( CBCS )
CyberLink Task SCheduler ( CTS )
Creative Service for CDROM Access
Cyberlink Media Library Service
France telecom Routing Table Service
InstallDriver Table Manager
iPod Service
Planificateur LiveUpdate automatique
PnkBstrA
PnkBstrB
Ulead Burning Helper
Service Partage réseau du lecteur Windows Media
Tu pourrais me dire ce que je dois décocher ....
Merci beaucoup :)
Garde ceux là:
Ati HotKey Poller
ATI Smart
Kaspersky
iPod Service
Creative Service for CDROM Access (je ne sais pas ce que c'est)
France telecom Routing Table Service (ça non plus...)
Désolé du retard, oublies pas de recocher Masquer les services MS car la case se décoche à chaque fermeture de la fenêtre.
C'est quoi cette bête? :heink: Un truc installé par le Kit de connexion Orange? :neutre:
Moi je pense que seul l'antivirus est nécéssaire...
De tte façon,sa ne coute rien de décocher,il faut tester et voir par la suite si la connection est toujours dispo..
Tu as ce logiciel qui te permet aussi de regler les services natif de XP et de les configurer au mieux afin d'optimiser l'OS
angeldisc.free.fr...
@+ Vins
Edité le 08/06/2007 à 19:45
Merci klump ainsi qu'à juju251,
J'ai suivi vos conseils et ca marche nickel
Pour ce qui est de Creative Service for CDROM je pense que ca a un rapport avec mon lecteur MP3 qui est de cette marque, et non un Ipod qui doit avoir un rapport avec itunes....
Ensuite France télécom Routing Table service doit avoir un rapport avec le kit de connexion Orange, comme le dit juju251.
Vins83, je vais voir pour ce petit logiciel que tu me propose, mais avec ces modifications je pense étre plus que satisfait
Encore un grand merci à vous pour avoir pris le temps de me répondre ;-)
14 messages
Filtrer ok
 Sujets Similaires:
