j ai du 10 mega chez noos..
sinon si ca vous parles plus qu a moi 3dmark 2006 result:2560
et le recapilatif de ma config
SystemInfo version 3.9
Stylesheet version 3.9
CPU Info
Physical Processors 1
Logical Processors 2
CPU 1/1
Intel® Pentium® 4 CPU 3.20GHz
Manufacturer Intel
Family Intel® Pentium® 4 CPU 3.20GHz
Architecture 32-bit
Internal Clock 3.2 GHz
Internal Clock Maximum 3.2 GHz
External Clock 200.0 MHz
Socket Designation Socket 478
Upgrade Socket 478
MultiCore 1 Processor Core
HyperThreadingTechnology Available - 2 HTT Processors per Core
Capabilities MMX, CMov, RDTSC, SSE, SSE2, SSE3, PAE
Version Intel® Pentium® 4 CPU 3.20GHz
Caches
Level 1 16 KB
Level 2 1 MB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.2180
Primary Device NVIDIA GeForce 7800 GS
Cooperative Adapters false
Display Device 1/1
NVIDIA GeForce 7800 GS Driver 9.1.4.8
Description NVIDIA GeForce 7800 GS
Manufacturer NVIDIA
Total Local Video Memory 256 MB
Total Local Texture Memory 240 MB
AGP Aperture Size 128 MB
Driver File nv4_disp.dll
Driver Version 9.1.4.8
Driver Date 8-16-2006
Driver WHQL Certified true
Max Texture Width 4096 px
Max Texture Height 4096 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3.0
Pixel Shader Version 3.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 0.0 Hz
VGA Core Clock 8.9 MHz
PCI
Name NVIDIA GeForce 7800 GS
Vendor ID 0x10de
Device ID 0x00f5
SubSystem ID 0x037c10de
Revision ID 0x00a2
Bus
Type AGP
Revision 3.0
Enabled true
Rate 8
Sideband Addressing Supported
Fast Write Supported
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
DirectShow
Version 9.0c
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
Color Space Converter
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
DivX Decoder Filter
DivX Demux
DivX Subtitle Decoder
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Internal Script Command Renderer
Line 21 Decoder
Line 21 Decoder 2
Lyric Parser
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
Nero DVD Decoder
Nero DVD Navigator
Nero Digital Audio Decoder
Nero Digital Parser
Nero ES Video Reader
Nero File Source (Async.)
Nero File Source / Splitter
Nero QuickTime Audio Decoder
Nero QuickTime Video Decoder
Nero Splitter
Nero Vcd Navigator
Nero Video Decoder
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Pad VU Data Grabber
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
DirectSound
Version 5.3.2600.2180
Speaker Configuration Stereo
Speaker Geometry Wide
Primary Device Realtek AC97 Audio
Sound Device 1/1
Realtek AC'97 Audio Driver 5.10.0.5750
Description Realtek AC97 Audio
Manufacturer Realtek
Driver File ALCXWDM.SYS
Driver Version 5.10.0.5750
Driver Date 11-17-2004
Max Supported 3D Hardware Sounds 25
HD Audio Support false
EAX Support Supported
PCI
Name Realtek AC'97 Audio
Vendor ID 0x8086
Device ID 0x24d5
SubSystem ID 0xa0021458
Revision ID 0x0002
Capabilities
Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
Memory Info
Total Physical Memory 2.00 GB
Free Physical Memory 1.57 GB
Total Pagefile Memory 3.85 GB
Free Pagefile Memory 3.58 GB
Memory Array 1/1
Max Module Capacity 4 MB
Location System Board
Use System
Supported Speeds -
Supported Types -
Supported Voltages -
Memory Slot 1/4
Installed Enabled Size 512 MB
Form Factor DIMM
Frequency 400.0 MHz
Slot A0 [Bank0/1]
Manufacturer None
Type Details -
Enabled Size 512 MB
Total Bit Width 64 b
Data Bit Width 64 b
Memory Slot 2/4
Form Factor DIMM
Frequency 400.0 MHz
Slot A1 [Bank2/3]
Manufacturer None
Type Details -
Enabled Size 512 MB
Data Bit Width 64 b
Memory Slot 3/4
Form Factor DIMM
Frequency 400.0 MHz
Slot A2 [Bank4/5]
Manufacturer None
Type Details -
Enabled Size 512 MB
Data Bit Width 64 b
Memory Slot 4/4
Form Factor DIMM
Frequency 400.0 MHz
Slot A3 [Bank6/7]
Manufacturer None
Type Details -
Enabled Size 512 MB
Data Bit Width 64 b
Motherboard Info
Supported Slot Types ISA, PCI, AGP
Manufacturer Gigabyte Technology Co., Ltd.
Model 8IPE1000-G/L
BIOS Vendor Award Software International, Inc.
BIOS Version F5
BIOS Release Date 08/19/2005
BIOS Properties Plug and Play, Flash, AGP
AGP
Revision 3.0
Rate 4x, 8x (8x enabled)
Available Rate 0x0000000c
Selected Rate 0x00000008
Sideband Addressing Supported (enabled)
Fast Write Supported (enabled)
PCI Devices
Manufacturer NVIDIA
Location Bus PCI 1, priphrique 0, fonction 0
Realtek RTL8169/8110 Family Gigabit Ethernet NIC
Manufacturer Realtek Semiconductor Corp.
Location Bus PCI 2, priphrique 9, fonction 0
Intel® 82801 PCI Bridge - 244E
Manufacturer Intel
Location Bus PCI 0, priphrique 30, fonction 0
Intel® 82801EB LPC Interface Controller - 24D0
Manufacturer Intel
Location Bus PCI 0, priphrique 31, fonction 0
Intel® 82801EB USB Universal Host Controller - 24D2
Manufacturer Intel
Location Bus PCI 0, priphrique 29, fonction 0
Intel® 82801EB SMBus Controller - 24D3
Manufacturer Intel
Location Bus PCI 0, priphrique 31, fonction 3
Intel® 82801EB USB Universal Host Controller - 24D4
Manufacturer Intel
Location Bus PCI 0, priphrique 29, fonction 1
Realtek AC'97 Audio
Location Bus PCI 0, priphrique 31, fonction 5
Intel® 82801EB USB Universal Host Controller - 24D7
Manufacturer Intel
Location Bus PCI 0, priphrique 29, fonction 2
Intel® 82801EB Ultra ATA Storage Controllers
Manufacturer Intel
Location Bus PCI 0, priphrique 31, fonction 1
Intel® 82801EB USB2 Enhanced Host Controller - 24DD
Manufacturer Intel
Location Bus PCI 0, priphrique 29, fonction 7
Intel® 82801EB USB Universal Host Controller - 24DE
Manufacturer Intel
Location Bus PCI 0, priphrique 29, fonction 3
Intel® 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Manufacturer Intel
Location Bus PCI 0, priphrique 0, fonction 0
Intel® 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Manufacturer Intel
Location Bus PCI 0, priphrique 1, fonction 0
Card Slots
PCI Slot
Order 1
Designation PCI
Type PCI
Characteristics 5.0V, 3.3V, PME Signal, SMBus Signal
Data Bus Width 32 b
Details Available, Long
IRQ 0
PCI Slot
Order 2
Designation PCI
Type PCI
Data Bus Width 32 b
IRQ 0
PCI Slot
Order 3
Designation PCI
Type PCI
Data Bus Width 32 b
IRQ 0
PCI Slot
Order 4
Designation PCI
Type PCI
Data Bus Width 32 b
IRQ 0
PCI Slot
Order 5
Designation PCI
Type PCI
Data Bus Width 32 b
IRQ 0
AGP Slot
Order 0
Designation AGP
Type AGP
Data Bus Width 32 b
Details In Use, Long
IRQ 0
System Devices
Name Intel® 82801 PCI Bridge - 244E
Manufacturer Intel
Name Intel® 82801EB LPC Interface Controller - 24D0
Manufacturer Intel
Name Intel® 82801EB SMBus Controller - 24D3
Manufacturer Intel
Name Intel® 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Manufacturer Intel
Name Intel® 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Manufacturer Intel
USB Devices
Description Concentrateur USB racine
Driver Date 7-1-2001
Driver Version 5.1.2600.1106
Device Class Universal Serial Bus Controller
Description Concentrateur USB gnrique
Driver Version 5.1.2600.0
Description Priphrique USB composite
Description USB Device
Description Priphrique audio USB
Driver Version 5.1.2535.0
Device Class Sound, Video or Game Controller
Description Priphrique de stockage de masse USB
FireWire Devices
Monitor Info
Monitor 1/1
Name HYUNDAI ImageQuest Q90U D-sub
Manufacturer Hyundai ImageQuest Co., Ltd.
Max Width 1280 px
Max Height 1024 px
Operating System Info
Name Microsoft Windows XP
Version 5.1.2600
PlatformId 2
Service Pack Service Pack 2 (v2.0)
Suite 768
Product Type 1
Media Center false
Windows Environment 32-bit
Locale FR
Desktop Width 1280 px
Desktop Height 1024 px
Desktop BPP 32 b
Internet Explorer Version 62900.2180
DEP
Hardware Support false
Applications Protected false
Drivers Protected false
User Option On for essential Windows programs and services only
Open Processes
Name PID Memory Usage
3DMark06.exe 364 14 MB
alg.exe 108 3 MB
csrss.exe 620 3 MB
ctfmon.exe 1592 5 MB
explorer.exe 1872 18 MB
firefox.exe 3920 53 MB
lsass.exe 700 1 MB
msmsgs.exe 1688 2 MB
nvsvc32.exe 1812 3 MB
pccguide.exe 1608 6 MB
PcCtlCom.exe 1840 6 MB
rundll32.exe 1544 3 MB
services.exe 688 4 MB
smss.exe 564 356 KB
SOUNDMAN.EXE 1616 2 MB
spoolsv.exe 1428 4 MB
svchost.exe 900 4 MB
svchost.exe 964 4 MB
svchost.exe 1060 21 MB
svchost.exe 1152 3 MB
svchost.exe 1224 3 MB
System 4 220 KB
System Idle Process 0 16 KB
Tmntsrv.exe 2032 4 MB
TmPfw.exe 952 6 MB
tmproxy.exe 184 33 MB
winlogon.exe 644 3 MB
wmiprvse.exe 1772 5 MB
wmiprvse.exe 588 6 MB
Open Applications
3DMark06
Tlcharger des logiciels, pilotes et utilitaires - Mozilla Firefox
Logical Drives
Letter Label Type Capacity Available
A: Floppy 0 B 0 B
C: Hard Disk 19.53 GB 11.77 GB
D: Hard Disk 19.53 GB 9.25 GB
E: Hard Disk 17.58 GB 9.17 GB
F: CD-ROM 0 B 0 B
H: Floppy 122 MB 15 MB
Storage Devices
Storage Device 1/3
ST380011A
Device Drive Type Hard Disk
Name ST380011A
Manufacturer (Lecteurs de disque standard)
Model ST380011A
Vendor ID String ST380011
Product ID String ST380011A
Product Revision String 8.01
Serial Number 5JVBDJ0B
Interface Type IDE
Device Bus Type ATA
Capacity 74.40 GB
Drive Letters C: D:
CD Max Read Speed 0
CD Read Capabilities -
CD Write Capabilities -
DVD Read Capabilities -
DVD Write Capabilities -
SMART Supported (disabled)
Acoustic Management Not Supported
Storage Device 2/3
Infineon USB Flash Drive USB Device
Name Infineon USB Flash Drive USB Device
Model Infineon USB Flash Drive USB Device
Vendor ID String Infineon
Product ID String USB Flash Drive
Product Revision String 2.00
Interface Type USB
Device Bus Type USB
Capacity 118 MB
Drive Letters H:
CD Max Read Speed 0
SMART Not Supported
Storage Device 3/3
SONY DVD RW DRU-810A
Device Drive Type DVD
Name SONY DVD RW DRU-810A
Manufacturer (Lecteurs de CD-ROM standard)
Model SONY DVD RW DRU-810A
Vendor ID String SONY
Product ID String SONY DVD RW DRU-810A
Product Revision String 1.0e
Serial Number 813004068810ACE7050
Interface Type <unknown>
Device Bus Type ATA
Capacity 0 B
Drive Letters F:
CD Max Read Speed 356
CD Read Capabilities -R, -RW
CD Write Capabilities -R, -RW
DVD Read Capabilities -ROM, -R
DVD Write Capabilities -R
SMART Not Supported
